Krebs Posted October 25, 2014 Report Posted October 25, 2014 pai ei eu implementat si sistemul de "inchiriere" , insa e valabil doar in USa , tot asa in sistem de share joci. Quote
F&F Posted October 25, 2014 Report Posted October 25, 2014 Sau o fi ciugulit niște boabe de struguri... Quote
Pole Posted October 25, 2014 Report Posted October 25, 2014 nu mai pot cu Alien Isolation, e foarte fain asa cum am tot zis, insa mi-a dat cu stres astazi de mi-a scazut si glicemia si cred ca-s abia la jumate. pauza ca nu mai pot. Quote
mihaiMAN63 Posted October 28, 2014 Report Posted October 28, 2014 (edited) fiÈ›' https://www.youtube.com/watch?v=f8fk-PUNU68 Edited October 28, 2014 by mihaiMAN63 1 1 Quote
Krebs Posted October 29, 2014 Report Posted October 29, 2014 asta o sa-l iau mai spre decembrie , in prima faza o sa vina AC Unity si GTA V , iar ubishit oricum rezolva bugurile jocurilor dupa 1-2 luni de la lansare. lumea zice ca-i un far cry 3 imbunatatit, mie mi-a placut far cry 3 deci , nu-i problema. Quote
Krebs Posted October 29, 2014 Report Posted October 29, 2014 m-as duce la domo sa-mi iau si eu unul ,dar n-au http://www.razerzone.com/gaming-audio/razer-leviathan Quote
WLF Posted October 29, 2014 Report Posted October 29, 2014 Mi se pare o poza atat de stupida. Deci te chinui sa tragi toate firele ascuns, dar te joci cu manetele legate cu fir de xbox, de parca n-ar fi wireless. 1 Quote
Pole Posted October 30, 2014 Report Posted October 30, 2014 krebs, imi face acum PS4 update la v.2.0, putem juca in share play ceva ? adica sa facem o proba ? un joc pe care eu nu-l am, dar il ai tu, sau invers ? sunt curios cum merge treaba Quote
Scufi Posted October 30, 2014 Report Posted October 30, 2014 US only e share play ala din ce stiu. Quote
Krebs Posted October 30, 2014 Report Posted October 30, 2014 krebs, imi face acum PS4 update la v.2.0, putem juca in share play ceva ? adica sa facem o proba ? un joc pe care eu nu-l am, dar il ai tu, sau invers ? sunt curios cum merge treaba merge foarte bine , i-am dat unuia sa incerce shadow of mordor si functioneaza perfect , doar ca cel ce foloseste shareul are rezolutia 720p , in schimb functioneaza perfect. acum joc Call of Duty Advance Warfare pe xbox 360 este destul de misto campania , insa duce cam spre SF si parca aduce destul de mult cu Crysis.. apropo grafica de pe 360 este destul de misto in cazul acestui joc, ma gandesc ca pe ps4 o sa arate criminal, pe 3 este lansarea . daca vrei sa incerci share play facem , dar trebuie sa te adaug iar in lista de prieteni. Quote
Pole Posted October 31, 2014 Report Posted October 31, 2014 mi-ai dat remove friend ? you bitch ! Quote
Krebs Posted October 31, 2014 Report Posted October 31, 2014 mi-am facut reinitializare sistem la ps4 si am pierdut si salvari si mai multe , tot atunci am modificat si lista de prieteni (mergea foarte greu fiind prea multi) ,insa acum cu noul 2.0 nu mai sunt probleme oricum , decat 300 de persoane in lista , mai bine 20-30 cu care si joc. daca vrei sa vezi cum e cu share play iti trimit cerere de "prietenie" )) Quote
Pole Posted October 31, 2014 Report Posted October 31, 2014 mie dupa update mi-a crapat sistemul de 2 ori, o data fix in timp ce jucam Alien Isolation si era sa fac infarct, ca stii ca nu salveaza progresul decat la punct fix si a trebuit sa reaiu o ora de joc. apropos, sunt pe la final, gata e foarte misto. da, da, trimite-mi request sa vad cum e cu share-play. ar trebui sa leg consola la cablu de net ? ca eu o tin pe wi-fi... Quote
Krebs Posted October 31, 2014 Report Posted October 31, 2014 pe cablu ai transfer mai bun si mai stabil. dar cred ca ok si pe wifi , depinde ce rooter si net ai. apropo , sa nu ti consola in standby (rest mode mai nou) ca e posibil sa nu o mai poti porni , este un minunat bug ce a venit odata cu 2.0 Quote
Pole Posted October 31, 2014 Report Posted October 31, 2014 plm upc ala cu cea mai mare viteza a lor, n am avut probleme. Quote
Krebs Posted October 31, 2014 Report Posted October 31, 2014 (edited) pai nu ai probleme cu facebook si navigare , dar pt gameing s-ar putea in fine, afara au viteze proaste oricum , asa ca probabil e ok 5-10 mb/s de wifi , pe fir ai 50-100 ups este slab oricum prin comparatie cu fiber link 1000 de la rds , eu am fiberlink 500 Edited October 31, 2014 by Krebs Quote
Krebs Posted October 31, 2014 Report Posted October 31, 2014 da vrei si acum putem face theronminotis ?! ti-am trimis cerere de prietenie ))) poti sa-mi dai add de pe telefon daca ai aplicatia psn ce e misto la share play ca poti sa dai (controllerul tau celuilalt) sau sa joci impreuna, adica daca ai fifa (doar unul) il poti invita prin share play si jucati doi acelasi joc desi celalalt nu are jocul Quote
Pole Posted October 31, 2014 Report Posted October 31, 2014 nu stiam de aplicatia asta, ce tare, mi-am pus-o acum si eu, am dat add de pe tel Quote
Flappy Posted October 31, 2014 Report Posted October 31, 2014 Ma, voi observati cum Pole si Puiu au dezvoltat un limbaj comun? Add de pe telefon cu aplicatia PSN, eu habar n-am despre ce vorbesc p-aici. Mi-as lua, da' mi-e ca renunt si la putina mea viata sociala Quote
Pole Posted October 31, 2014 Report Posted October 31, 2014 hm, vad ca zice ca pot conecta si PS4 la telefon, o sa ma joc cu treaba asta, tre sa plec. Quote
Krebs Posted October 31, 2014 Report Posted October 31, 2014 (edited) nu stiam de aplicatia asta, ce tare, mi-am pus-o acum si eu, am dat add de pe tel daca ai consola in standby poti sa faci mai multe de pe telefon direct pe ps4 de exemplu poti sa joci comander in BF4 de pe telefon sau poti sa folosesti telefonul pe post de controller, poti chiar sa dai drumul la un joc de downloadat de pe store si cand ajungi acasa sa il ai gata instalat ,iar daca ai xperia Z3 poti sa folosesti telefonul cu noul FW 2.0 ca un playstation vita si joci jocurile de ps4 direct pe telefon. Edited October 31, 2014 by Krebs Quote
Krebs Posted November 3, 2014 Report Posted November 3, 2014 joc facut 100% de romani https://www.youtube.com/watch?v=1HzCTa1csu4 Ceasca-i pe perete! Quote
Pole Posted November 3, 2014 Report Posted November 3, 2014 da il stiu, am auzit de el, seamana putin cu Limbo. 1 Quote
