Tamer Posted January 6, 2015 Report Posted January 6, 2015 Proaspat dezvaluit la CES 2015, noul BMW M4 Iconic Lights prezinta noile tehnologii LaserLight 2.0 si OLED ale producatorului bavarez. Personal mi se pare putin ciudat faptul ca pe Seria 3/4 exista 4 tipuri de faruri: halogen, xenon, LED si, acum, LaserLight. Extras de pe BimmerPost: Shining example of innovative technology: anti-dazzle Laserlight and laser projection.BMW Laserlight sets new standards in terms of beam range and brightness. Inside the laser headlights, the “coherent†monochromatic blue laser light is converted into harmless white light. A special optical system directs the rays from the high-performance diodes onto a phosphor plate inside the light, which converts the beam into a very bright white light that is similar to natural daylight and pleasant to the eye. Despite consuming 30 percent less energy, the parallel light beam is ten times more intense than that produced by halogen, xenon or LED light sources. BMW Laserlight also has a beam range of up to 600 metres, more than twice that of conventional headlights, for increased safety in the dark. The camera-based BMW Selective Beam system, which is controlled by dynamic actuators, prevents oncoming or preceding vehicles being dazzled and allows the laser high beam to be left on at all times.Enhanced safety through connectivity. Extensive integration of the innovative Laserlight with other vehicle systems allows a variety of intelligent lighting functions to be implemented. Integration with the navigation system, for example, allows the proactive Adaptive Headlight control system to illuminate corners even before the steering wheel is turned. Laserlight also adds a new dimension to the Night Vision system’s Dynamic Light Spot function. In pitch-dark conditions, people and animals can be detected from a distance of up to 100 metres, by infrared camera, and “spotlighted†by the laser-based Dynamic Light Spot. This is a longer range than that of any other system. Also, if the vehicle detects reduced clear road width ahead, the laser headlights can be used to provide “narrow clearance†lighting. A laser projection function indicates the exact width of the vehicle in relation to the road to allow safe passage through the narrow space. BMW M4 Concept Iconic Lights also showcases a further “visionary†system: “High Power Laser†diodes. This system projects driver information directly onto the road in front of the vehicle, allowing drivers to concentrate optimally on the traffic even in pitch darkness.OLED rear light cluster with three-dimensional effect. Organic light-emitting diodes – OLEDs – are an innovative, efficient, sustainable light source that form the basis for the BMW Organic Light system. OLEDs have a low power consumption, which helps to further reduce vehicle CO2 emissions. Another sustainable feature of this technology is the fact that no expensive rare earth metals are required in the production process. Unlike ordinary LEDs, which are a point light source, OLEDs produce light uniformly over their entire surface. The OLED elements are very thin, with a thickness of just 1.4 millimetres. Also, the individual modules can be activated separately, generating new possibilities for creating different lighting effects at the rear light clusters.Different lighting effects in different driving modes. In the past, rigorous legal requirements regulating the brightness of vehicle lighting have limited the number of lighting functions that it was possible to implement with OLED technology. On the BMW M4 Concept Iconic Lights model, BMW Organic Light is used in the tail lights and rear direction indicators. By activating the OLED segments individually, it is possible to create different rear lighting effects in different driving modes. Whereas normally the L-shape is wide and uniformly illuminated, in Sport mode a different-shaped light pattern can be used by activating only some of the OLED segments. The rear light then appears as a narrow, focused and sharply defined “strip†of light. Quote
Calin Posted January 6, 2015 Report Posted January 6, 2015 Personal mi se pare putin ciudat faptul ca pe Seria 3/4 exista 4 tipuri de faruri: halogen, xenon, LED si, acum, LaserLight. 5. Exista si feshtilla dimmed light 2 Quote
Pole Posted January 6, 2015 Report Posted January 6, 2015 arata absolut spectaculos, i'm in love. Quote
Krebs Posted January 7, 2015 Report Posted January 7, 2015 (edited) Am vazut azi un X6M d-asta nou , cu stopurile alea de M4, numar rosu..gagica la volan era alb si apropo , aiurea scobiturile ochi de pisica laterale din bara X6 si X5 nou Edited January 7, 2015 by Krebs Quote
Cefi Posted January 7, 2015 Report Posted January 7, 2015 Ne bucuram ca ai văzut un x6m paiutule Quote
Pole Posted January 7, 2015 Report Posted January 7, 2015 il asteptam pe blue sa ne explice cat de naspa sunt stopurile alea si cat de misto sunt la audi. 2 Quote
Flappy Posted January 7, 2015 Report Posted January 7, 2015 Mai dureaza. Saptamana asta am inteles ca ar fi schimbul doi. Quote
Krebs Posted January 7, 2015 Report Posted January 7, 2015 (edited) pai nici nu stiam ca s-a lansat(cefri), d-asta am tinut si minte iar cand am vazut gagica la bord.. mi-au trecut prin cap gandurile normale.. cata p**a a supt asta ma nene !? Edited January 7, 2015 by Krebs Quote
Krebs Posted January 7, 2015 Report Posted January 7, 2015 stiam ca !? = mirare , probabil nu stiam bine, iar. Quote
Scufi Posted January 7, 2015 Report Posted January 7, 2015 De ce întrebi? vroia sa vada daca renteaza Quote
Krebs Posted January 7, 2015 Report Posted January 7, 2015 Raresica, nu mai suport suspansu' , zi-mi de pe acum , unde am gresit ?! 2 Quote
Pole Posted January 7, 2015 Report Posted January 7, 2015 bai nene, ia nu va mai luati aiurea de puiu! ps: parca era mai urat x6-le nou, asta din poza arata demential, sau e efectul M. Quote
F&F Posted January 7, 2015 Report Posted January 7, 2015 Raresica, nu mai suport suspansu' , zi-mi de pe acum , unde am gresit ?! In exprimare, respectiv ordinea ideilor. Quote
Simi ON Posted January 7, 2015 Report Posted January 7, 2015 Raresh, ai pus-o daca te ia Pole in colimator, o sa ma regreti mai ceva ca pe Blitzu care te-a format Quote
F&F Posted January 7, 2015 Report Posted January 7, 2015 bai nene, ia nu va mai luati aiurea de puiu! .La mulți ani! Quote
Simi ON Posted January 7, 2015 Report Posted January 7, 2015 Din tine-o sa ramana doar ghetuțele... Quote
Pole Posted January 7, 2015 Report Posted January 7, 2015 gata, m-a dezarmat, I'm stupid that way... Quote
Tamer Posted February 16, 2015 Author Report Posted February 16, 2015 Video: https://www.youtube.com/watch?v=kJwSrArUpmM#t=52 Quote
